DNAC Violation shows Wired Client - IPDT for interfaces with AP
Hello all,
we have recently upgraded our DNAC from 2.3.3.7 to 2.3.5.5. After the upgrade I noticed that under Compliance Summary --> Network Settings, we get a violation "Wired Client - IPDT/Interface x" for all interfaces that have Access Points connected to them and a status of "Added". We are also hitting the bug "CSCwf99801", so the compliance fix is not being implemented. Apart from that, the interfaces do have the "device-tracking attach-policy IPDT_POLICY" command configured. What is the meaning of the violation?
I am also attaching a print screen of the violation.
Any ideas?
Thanks!
maflesch
This is actually a duplicate of CSCwe55226. As such, the fix is supposed to be in in 2.3.5.4+. The logic is built between how the port is defined and how the port is looked at for SDA logic. If you are still seeing this issue, I would suggest opening a TAC case so they can investigate.
maflesch
