Fabric Capability per WLAN
JL421-Retired
In the SD Access Wireless Deployment Guide it shows that Fabric capability is enabled on a per WLAN basis, however when you try to do this in practice (DNA-C 1.2.5) it tells you than only one type of policy can be enabled per Site. Is this planned to change as I have a few legacy WLANs that for the time being need to run outside the fabric, and some that can run inside the fabric?
For example our main production data and voice networks can be fabric enabled, but our Guest and specialty device WLAN use a mobility anchor to go to a controller dedicated to that specific traffic.
Gaur Samal
you can add fabric enabled or non fabric ssid's to a single network profile which is linked to 1 site in 1.2.5 and it works properly.
for example :
Screen Shot 2018-10-06 at 5.33.49 AM.pnghere you can see i have 2 SSID's one is fabric and 1 is non fabric. DNAC version is 1.2.5.
Could you please explain what error you are getting? please paste the error snapshot.
