Having issue while estabisling Tunnel using ikev2 and ipsec.
Ammartehsein
I am testing tunnel in lab but it is not working. Topology is very simple only 2 routers. I router is acting like a hub and 1 is as client. On Hub router 1 loopback interface.
Client router config:
Building configuration...
Current configuration : 4823 bytes
! Last configuration change at 14:42:21 UTC Fri Aug 30 2024
version 15.9
hostname Najam-Abha
boot-start-marker
boot-end-marker
no logging console
aaa new-model
aaa authentication login default local
aaa session-id common
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
redundancy
no cdp run
track 1 ip sla 1 reachability
track 2 ip sla 2 reachability
track 3 list boolean or
object 1
object 2
object 4
track 4 ip sla 4 reachability
crypto ikev2 proposal default
encryption des 3des
integrity md5
group 1 2
crypto ikev2 policy default
match fvrf any
proposal default
crypto ikev2 keyring key
peer ANY
address 0.0.0.0 0.0.0.0
identity address 0.0.0.0
pre-shared-key act123456
crypto ikev2 profile prof
match identity remote address 0.0.0.0
authentication remote pre-share
authentication local pre-share
keyring local key
crypto ikev2 dpd 10 2 periodic
crypto isakmp policy 20
encr 3des
hash md5
authentication pre-share
group 2
lifetime 3600
crypto isakmp key cisco123 address 0.0.0.0
crypto ipsec transform-set test_trans esp-aes esp-sha-hmac
mode tunnel
crypto ipsec transform-set new_test_port1 esp-3des esp-md5-hmac
mode tunnel
crypto ipsec profile newprof
set transform-set new_test_port1
set pfs group2
set ikev2-profile prof
crypto ipsec profile test_profile
set transform-set test_trans
interface Tunnel10
ip address 172.27.10.30 255.255.252.0
no ip redirects
ip mtu 1200
ip nhrp network-id 11
ip nhrp nhs 172.27.10.1 nbma 157.175.8.17 multicast priority 1
ip nhrp shortcut
ip tcp adjust-mss 1190
tunnel source GigabitEthernet0/1
tunnel destination 157.175.8.17
tunnel protection ipsec profile newprof
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 185.62.177.81 255.255.255.252
ip virtual-reassembly in
rate-limit input 13024000 2442000 4884000 conform-action continue exceed-action drop
rate-limit output 13024000 2442000 4884000 conform-action continue exceed-action drop
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 157.175.8.17 255.255.255.255 GigabitEthernet0/1
ipv6 ioam timestamp
HUB config:
Current configuration : 4298 bytes
! Last configuration change at 14:30:19 UTC Fri Aug 30 2024
version 15.9
service password-encryption
hostname Hub_CiscoTeltonika
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
encryption 3des
integrity md5
group 2
match fvrf any
proposal default
peer Spoke1-KEY
keyring local key
crypto isakmp policy 100
encr 3des
hash md5
group 2
crypto isakmp invalid-spi-recovery
crypto ipsec transform-set test_trans esp-3des esp-md5-hmac
mode transport
crypto ipsec transform-set DMVPN2 esp-3des esp-md5-hmac
mode transport
crypto ipsec profile DMVPN2
set security-association lifetime seconds 86400
set transform-set DMVPN2
set pfs group2
crypto ipsec profile DMVPN_hub
set pfs group2
interface Loopback1
ip address 157.175.8.17 255.255.255.255
interface Tunnel1
description "Portabella 2 for Cisco and Teltonika Spokes"
ip address 172.27.10.1 255.255.252.0
no ip redirects
ip mtu 1200
tunnel mode gre multipoint
tunnel protection ipsec profile DMVPN_hub
ip address 192.168.1.1 255.255.255.252
duplex auto
speed auto
media-type rj45
ip address 185.62.177.82 255.255.255.252
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip http server
ipv6 ioam timestamp
It is multipoint gre tunnel so mode should be multipoint at hub.
No need to create separate proposal other than default. The issue was minor tunnel source at hub should be loopback.
5 Replies 5
MHM
tunnel destination 157.175.8.17 <<- in spoke remove this command
In spoke under tunnel add
Tunnel mode gre multipoint
In spoke abd hub under tunnel add
Tunnel key 11
For LO use by hub are this LO is reachable from spoke ?
MHM
I sure bring good luck' when I reply the issue is solved immediately.
Maybe you can put my name in your car for more good luck lol...
MHM
Thanks buddy for quick response. You are indeed lucky
