how to enable AAA-DHCP monitoring in DNA
Ahmed Tarek
Level 3
Level 3
hi all,
i need to monitoring AAA - DHCP monitoring in DNA 2.3.5
as 2 images i uploaded there is ( no data to display ) , how can add AAA and DHCP to check ?
thanks
6 Replies 6
M02@rt37
thanks M02@rt37 for your reply
unfortenatelly i already check this guide, but the guide is depending on that feature is running, but in my case i think there is service missing or something need to activate.
pls check my 2 images.
thanks again
guruvignesh
Hello Ahmed,
To monitor AAA and DHCP in Cisco DNA Center 2.3.5:
  1. Access DNA Center and go to Assurance.
  2. Choose AAA or DHCP monitoring.
  3. Configure settings like devices and metrics.
  4. Apply filters and criteria for focus.
  5. Save settings to start monitoring.
Ahmed Tarek
Level 3
Level 3
Hello M02@rt37
there is no ( Configure settings like devices and metrics.  ) to configure
always see ( No Data to display )
Hello @Ahmed Tarek ,
Take care of the following limitations when configuring AAA and DHCP monitoring:
AAA Limitations
  • AAA Network Service supports wireless clients and Local mode.
  • AAA Network Service does not support the following:
    • AireOS Wireless Controller
    • Flex mode or fabric mode
DHCP Limitations
  • DHCP Network Service supports wireless clients and Local mode.
  • DHCP Network Service does not support the following:
    • SD-Access fabric clients
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
thanks @liviu.gheorghe for your reply,
but i still not know how to run this feature,
as it still not appear
