03-04-2024 04:15 AM - edited 03-04-2024 05:58 AM
Hello Team,
Currently we have deployed 9800 wlcin our infra and associated the wlc in DNAC center.
But we are not able to view the client assuarnce data in the DNA Center
Anjana.
03-04-2024 06:16 AM
+Is your WLC showing a health score in the inventory? Also, do you have the wireless endpoint collection enabled in your network settings? (Design > Network Settings > Telemetry > Enable Wireless Telemetry)
+If there's no healthscore, try updating the telemetry settings. This will create the required trustpoints and configurations on the device to show a health score.
+From the Inventory:
Select the Device > Actions > Telemetry > Update Telemetry > Check the box for 'force configuration update' > And proceed through the steps.
+You can monitor monitor the task from the Activities > Tasks page. If it fails, can you share the failure reason? If it succeeds, check if the telemetry connection is 'active' or 'connecting'. Depending on the SW Version, the command is either:
sh telemetry internal connection
or
sh telemetry connection all
03-04-2024 07:44 PM
Thanks for the update.
Can you pls update what is the exact configuration or exact set of file being pushed to AP's and wlc when telemtry being enabled in the DNAC.
Anjana
03-05-2024 07:53 AM
You'll get an overview in this page:
When you get to the last step where you can choose to 'apply' the config, check the "Generate Configuration Preview" option to see exactly what's pushed
And then you can either click the "Work Items" Hyperlink at the bottom right, or navigate to the Activities > Work Items page. You'll see a details list of all configurations pushed.
