how to load ap's on dna spaces ?
venkat_n7
I have loaded maps on dna space center and ap's aswell, but not sure how to add those ap's over the map, any idea how i can add access points on dna space maps ?
Please rate comments and support
with regards,
Venkat
AdamF1
How did you integrate dna spaces with your existing environment?
I use dna center integration with dna spaces so my maps and aps sync automatically once I allow that map/floor to sync with it.
If you imported the maps I believe there should have been an option to export everything and not just the map.
