How to move Areas to different node in Hierarchy in Cisco DNA Center
AndrewJR46219
I'm working in Cisco DNAC, Design, Network Hierarchy attempting to move existing areas, buildings and floors from one node to another in the Hierarchy. The point of it all is that we're doing some re-naming work that's going to end up with several sites moving to a new Node under Global that we're creating. Hopefully this makes sense, it's my first time working in DNAC. Thanks in advance for the assistance.
Torbjørn
I don't believe there is a way to do this in the DNAC GUI. What you can do to save some time is export hierarchy in the GUI, copy and rename the areas in the CSV file and import it to the hierarchy in the GUI. Note that this will only create new areas in the hierarchy, not actually move any areas/devices/IP pools etc.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
