How to remove SNMP credentials from switches using DNAC?
Graeme Nelson
We are moving from SNMPv2c to SNMPv3 wherever we can ... rolling out the SNMPv3 credentials from DNAC is super-easy, but how do you get DNAC to remove the old SNMPv2c credentials/settings?
Preston Chilcote
You can create a configuration template with the needed "no snmp" commands.
https://blogs.cisco.com/networking/dnactemplatesdayn-pt4
Yay, DNAC templates. <said with sarcasm>
I was hoping for something simpler than DNAC templates - my experience with them so far is not good - but I suppose I'll need to get adept at using them sometime .. I suppose something relatively small and simple as removing old/unwanted credentials is a good starting point.
Thanks for your help.
