I see critical issue P2, power supply failure on on device from DNA
chamies2011
Hello
I see critical issue P2, power supply failure on cisco device 38xx
After check, device health :10
now looks ok.
the message still appear in DNA on critical issues
My question is, by default this message should be clear or disappear by system(DNA) if all ok or not at all ?
if yes how long time to be updated need ?
or the way is only select the two options available in DNA  :  resolved issues / ignored issues  ?
Thank you
Chamies
Preston Chilcote
It will require your manual intervention to Resolve the issue.  Then, if it is seen again, a new Issue will be reported.
