IE-3100 "IP default-gateway" disappears after a power reboot.
TEAM_ADP_CDGBS
Hello everyone,
I have several Cisco IE-3100 switches that lose part of their configuration after a power cycle.
The switches lose the following configuration line: ip default-gateway.
I have to log in to the switch console to re-enter the command: ip default-gateway.
I had to create a script to add the configuration line back if the SLA tracker stops responding to pings.
Do you have any ideas on how to resolve this bug without using a script?
Thank you very much.
Mark Elsen
  -  @TEAM_ADP_CDGBS             FYI :  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwp02600
                                                              https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf68802
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
