Is there an upgrade guide that covers DR upgrade steps?
shane.carnahan
Looking to upgrade and running deployment of CatC from 2.3.7.6 to 2.3.7.9. It's running in DR already. Trying to find the steps to do this upgrade. Not sure if I need to break/pause DR and upgrade the witness node first and then active and backup. I've looked in the 2.3.7.9 upgrade guide and don't see it.
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/upgrade/b_cisco_catalyst_center_upgrade_guide/m_upgrade_to_cisco_dna_center_2_3_7_x.html
Thank you @maflesch I did find what I was looking for. It's under the "Administer you disaster recovery system" in the guide you linked.
Procedure
Step 1
Place your system on pause.
Step 2
Upgrade the appliances at your main and recovery sites to the latest Catalyst Center version (see the Cisco Catalyst Center Upgrade Guide).
Step 3
Do one of these tasks:
Step 4
Rejoin your system.
Note
After upgrading to Catalyst Center 2.3.7 from version 2.3.4 or earlier, data migration takes place the first time a Rejoin operation is initiated. As a result, it will take longer for this operation to complete. The migration may add minutes or even hours to the completion time, depending on the amount of Catalyst Center data that's present. Keep in mind that this data migration only happens after an upgrade. This will not impact subsequent Rejoin operations.
During this one-time data migration from MongoDB to fileservice, you can ignore high disk utilization critical alerts for MongoDB. These alerts are temporary. After the Rejoin operation completes, the disk consumption decreases to expected values.
Procedure
Step 1
Step 2
Step 3
Step 4
Rejoin your system.
Note
