ISE and DNAC Integration
SecurityEng99
The Cisco ISE using an internal  certificate for the Admin and the CA trust certificate is uploaded to Cisco ISE Trusted Certificates. When I try to connect DNAC to ISE, I received the error message below.
Please advise
Boort
I have seen this once before. When i got this error it was a ghost certificate in the ISE certificate store. We had to get TAC to log in to the ISE Linux shell and manually remove it on all nodes in the cluster.
So, unless this certificate is one you expect to be in your ise deployment i would check if its a ghost certificate.
Boort
