ISE, DNA Center, SGT and Posture - Concept questions
davidfield
Level 3
Level 3
Hello All,
Starting to get into ISE and DNA and a couple of queries if someone can point me in the right direction.  There is a lot of content on both subjects and I cant quite piece together where DNA Center is necessary when it comes to SDA.  For example do I need DNA Center to implement Trustsec, SGT's and Posture?  From what I can determine ISE covers this and DNA Center is more monitoring along with some Admin integration or am I miss-understanding.
Also, from a licensing perspective if I were to use Cisco 9200's in my lab for my edge switches to achieve SGT and Posture I just need the Network Essential's or is it necessary to have Network Advantage licensing?  I appreciate I'll need the DNA Advantage term license but not be needed if DNA Center not used.
Has anyone a link that explains in more detail or a brief summary?
Thanks in advance
Dave
jedolphi
Hi Dave. Manually (by hand on the CLI, without DNA Center) deployed wired and wireless Cisco infra with ISE will give you capability to implement Group-Based Policy (aka TrustSec), SGT and posture.
Network Advantage and DNA Advantage is required for GBP in C9K switches.
If you choose to proceed with DNA Center and SD-Access you will get automation of the fabric (no manual deployment) which natively support GBP and Network Virtualisaiton, Assurance, Endpoint Analytics, Trust Analytics and Group-Based Policy Analytics. If you're not sure what those things are then searching some of the most recent presentations on ciscolive.com would be a good way to learn.
In short: deployment and visibility of campus networks, GBP and SGT is easier with DNA Center.
jedolphi
Thanks jedolphi
I appreciate you providing some clarity which is very helpful.
Hello again a bit more on this query if I may.
We are proposing to have a Core switch stack with Advantage licensing and Access Switch stacks with Essentials licensing.  The Access Switches would be configured with SXP to ISE to maintain the IP to SGT mapping.  The nature of the site is that the Access switch traffic is primarily to/via the core.  My thinking is that I can use SXP to ISE for the Access Switches to apply the SGT tag to the packet and the core switches become the enforcement point.
What are the issues with this approach?  I appreciate I'm not enforcing at the Access Switch port but there is a big difference in Advantage vs Essentials costs which is proving to be a blocker for the client.  Am I missing something or miss-interpreted a concept here?
Any input on why not to go down this route would appreciated.
Best Regards
David
