Hi Everyone,
First post here since im pretty new to the world of Cisco. Just a quick LAN Automation query which hopefully one of you gurus can answer.
Running DNA in a 3 node cluster setup - LAN automation has previously always used the 'Enterprise VIP' to configure devices. On the current Edge node I used with LAN automation i noticed this has changed to the 'Management VIP' address. Once LAN automation is complete and Edge node is provisioned i can see the 'Management VIP' address is used throughout its configuration instead of the 'Enterprise VIP', has anyone has seen this before? is it normal behaviour or something that needs resolving?
Many thanks
Mark
