Monitoring Cisco DNA Center node health using Grafana (System > System 360 > Monitoring)
I am trying to monitor the Cisco DNAC node health status using the monitoring capabilities (System > System 360 > Monitoring) comes with Controller.  Like to trigger an alert (Grafana alert) if the node is unhealthy and not part of the cluster. The "node" dashboard has a panel named "node status" but it's not showing any data (attached). Is there:
  1. Any query / metric can be used from Grafana to identify node is unhealthy and not part of the cluster?
  2. Any API I can leverage to do the same.
Thanks.
0 Replies 0
