NCOB02107 - AP's unable to join controller
Hi All,
Facing below error issue while onboarding AP's to DNAC controller
NCOB02107: Executed Workflow Timed out. AP didn't join the controller. Please check connectivity/configuration to fix the issue.
Torbjørn
This indicates that your access point is unable to join your WLC for some reason. Are you 100% certain that there is no connectivity issue between your AP and your WLC(firewall rules, port auth etc)? Can you see anything in the logs of your WLC?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Hey Torbjon,
Connectivity from AP to WLC seems fine. From log on DNAC and AP, AP receiving the PNP config and starting CAPWAP discovery, but getting stuck.
On DNAC AP onboarding is getting completed 80% and after around 1 hrs. its giving error.
If we use external power injector its working fine.
Could you please suggest how we can upgrade the AP's before starting joining to DNAC/controller ?
