Need a Suggestion for a Internet switch
Mr.Kumar
Hello Everyone,
In our data center, we are currently using a 3850 as our internet switch, what is the best replacement for it within the $2.5k to 3k? It should support layer 3 routing. Thanks
Joseph W. Doherty
There are various 3850 models (and modules?), so if would be helpful if you could identify the exact hardware you're using now.  Also helpful would be to list any specific 3850 features that are necessary.  Lastly, noting any features you want that the 3850 doesn't support.
Likely, recommendation will be the 9K family, but it's an extensive family.
