Problem bulk importing AP's using CSV-file - DNACenter/Catalyst Center
Hello!
My organization recently upgraded DNACenter/Catalyst Center from version 2.3.5.6 to version 2.3.7.6. After this upgrade, I can no longer perform a bulk import of AP's using a CSV-file. I have used the same template before with success, but now I get an error message saying something is wrong with my CSV-file:
I've downloaded the template to make sure that the file I'm trying to use has the right syntax. I have concluded that the highlighted row is what my file is supposed to look like:
This is my file:
And this is how the Area/Building/Floor hierarchy looks like in DNACenter:
Does anyone here know what I'm doing wrong? I have tried other sites with the same result. Before the upgrade, I did not encounter this problem using the same template.
Mark Elsen
 - Not a direct reply , but check if you can find any useful logs to examine from :
              https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/dna-center/215683-quick-start-guide-on-what-logs-to-collec.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I will look into it, thank you!
