Reuse CLI Template Variables outside for loop
Tobias Heisele
Level 6
Level 6
Hi Community,
is it possible to reuse a Variable that has been set inside a for loop after the loop ended?
{% for interface in __interfaces %}
  {% if something matches %}
    {% set MyVariable = "This is a Test" %}
  {% endif %}
{% endfor %}
{{ MyVariable }}
Tobias Heisele
Level 6
Level 6
Got it (thx to stackoverflow) using a global dictionary
{% set global = {} %}
    {% set _ = global.update({MyVariable:"This is a Test"}) %}
  {% endif %}
{% endfor %}
{% set MyVariable = global["MyVariable"] %}
{{ MyVariable }}
Tobias Heisele
Level 6
Level 6
  {% endif %}
{% endfor %}
{{ MyVariable }}
DJW487
Level 3
Level 3
Thanks. I always like seeing little things like this.
