Routes redistribution in multi AS eBGP
ibzjuz
Hi everyone,
In eBGP, is it possible to distribute routes across multiple AS ? Like this :
AS1---AS2---AS3
Is it possible to redistribute AS1 routes to AS3 ?
Romain
Mike.Cifelli
You can accomplish this with eBGP. By default eBGP TTL is set to 1 so if you are not directly connected it is going to get discarded. However, you can fix it by issuing the ebgp-multihop command. So for example in your scenario it would look something like this:
#neighbor (AS3 IP) ebgp-multihop 2
And then vice versa
Then under the respective address family redistribute as you wish once your adjacency comes up. Good luck & HTH!
Thanks for your feedback.
My problem is that I don't have access to the AS3 router it's a provider router.
