Routing between Virtual Networks
scsc_tech
If multiple virtual networks are created in the SD fabric, is routing between them handled by the fusion router, or does it happen at the boarder/cp or edge nodes?
Tomas de Leon
The routing between Virtual Networks (VNs) is performed on the Shared Services\Fusion Router.  The Route Leaking occurs on that that router\switch.  The Fusion Router is connected to a Fabric Border.
SDA - Steps to configure Fusion Router
https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/dna-center/213525-sda-steps-to-configure-fusion-router.html
CISCO VALIDATED DESIGN
Software-Defined Access - Design Guide
https://www.cisco.com/c/dam/en/us/td/docs/solutions/CVD/Campus/CVD-Software-Defined-Access-Design-Sol1dot2-2018DEC.pdf
Tomas de Leon
Hi Thomas,
In the Fusion Router Setup PDF there is no vrf which contains the global routes. In the PDF there is only and exportstion / importation between the Univ and Campus VRF and later some injection work with the routemaps.
In the Cisco DNAC Deployment CVD there is a Global Routing VRF which gets exported and imported (See Page 52 in Cisco DNAC Deployment CVD).
Can you PLEASE explain / evalute what and why the correct way is when we have 2 border nodes connected to 2 fusion Routers (eBGP between Border and Fusion and iBGP between the 2 borders and also between the fusions)??
The links that I sent are only to be used as a reference and that each deployment will be different and we can not cover or predict every Border to Fusion or Transit Router.  Most examples that you will see are for demonstrating the simple route leaking between the Fabric\SDA VRFs.   Access to other networks that are part of the GRT will need to be imported into each VRF.  In addition, Fabric VNs\VRFs may need to be "exported" into the GRT so the external endpoints can reach SDA devices if needed.
Yes.  The IP Transit will use EBGP to connect to the Fusion\Transit Router. If you connect the Dual or Multiple Borders, they will use IBGP between the Borders.
I hope this helps
Mike.Cifelli
Routing between your VNs in your SDA fabric will occur on your fusion routers.  Your EBN/s will learn default routes via ebgp from your fusion/s.  On your fusions you will advertise and control via route leaking between each VN instance.  This will occur even when you have two users on the same edge node, but in separate VNs.  Obviously each scenario will be different depending on what you are attempting to accomplish.  It may not be a bad idea to utilize mutliple IP pools + SGTs in the same VN, and rely on CTS for security to potentially eliminate the need for fusion crossover.  On the contrary, multiple VNs also provide a legitimate level of security.
I believe Cisco is eventually going to allow EBNs to also act as Fusions in the future.
