struggle with DNA Jinja for-loop in templates
pieterh
Hi all,
I'm practicing with templates in Cisco DNA center (Version 2.3.3.7-72328)
And now I've been struggling with a Jinja for-loop in DNA templates
DNA center provides a sample template  Multi-Switch Template with Macro
in which the line {% for stack_num in range(1, number_of_stacks) %} is used
this command does not execute as I expect, it runs for a member less then specified
if i specify "4"  it runs for members 1, 2, 3.
part is explainable because the for loop runs from "0" to (but-not-included) the specified variable
specifying "1" as start helps to skip member "0" that not exist, but still the last executed "3" is instead of "4"
-> as such this example template is incorrect
what modification is needed to run until number_of_stacks ?
- simply specifying number_of_stacks +1number_of_stacks +(1)
   other variants did not help or gave unexpected result (for members 1 to 40 (!) )
- using a in-between variable for number_of_stacks +1 also did not help
searching for Jinja I found many interesting examples and tutorials,
but except from the from "0" to (but-not-included) , Google and I  did not succeed to find something helpful for this issue
any suggestions?
with above in mind,  Google helped me finding this page
     python - Finding the sum of numbers in jinja2 template using flask - Stack Overflow
this construction solved my problem:
     {% set range_end = 1|int + number_of_stacks|int %}
     {% for stack_num in range(1, range_end ) -%}
pieterh
looks like number_of_stacks +(1)  performs a concatenation instead (4+1=41)  of the intended addition
how do I make it an addition
