Switch Can't Loading firmware
khor-chia-quan
Hi Guys, I'm newbie in the Cisco switch and Network engineering.
Recently, I'm facing an issue with switch (Cisco Catalyst IE3x00 Rugged), my switch after power cycle cannot loading the firmware automatically. I only able to boot the firmware by manual.
for the rollback folder direction I have check with command is don't have the package file, where can I get it, or I should re-configure my package config.
The USB flash is not formatted to FAT16.
7 Replies 7
Leo Laohoo
Put the firmware into a USB flash and force the switch to boot the firmware from the USB flash drive.
boot usb0:filename.bin
Hi Leo,
I have tried, before but get the error messages.
Reboot the switch and post the entire boot-up process.
This is the entire boot-up process
Leo Thank you so much is solved my problem!!
Thank you very much for taking the time to provide feedback and confirming this issue has been solved.
