Unable to save configuration on Nexus 9k switches
philip-NTT
How can I fix this guys
copy running-config startup-config
[########################################] 100%
Configuration update aborted: request was aborted
Logfile output:
%SYSMGR-3-CFGWRITE_FAILED: Configuration copy failed (error-id 0x401E0000).
M02@rt37
Thanks for the explanation.
I will investigate to what exactly the engineer configured.
Kind Regards
balaji.bandi
what is the full model and what nexus code running ? what was the uptime ?
what was the changes done, you can check the differences show run diff command.
also try save to remote TFTP and USB see if that works.
there is possibility bug as mentioned M02@rt37  other post.
BB
