Using DNAC to automate reloads.
boydsr
Hello Cisco community. My organization is set on reloading our access switches annually and I'm tasked with determining a way to ensure this is done. I have used Cisco Prime to run a job using the CLI templates available there and am looking for a way to do the same via DNACenter. While I am reading through DNAC user guide I thought it best to utilize all the resources available and thought the community a great place to start.  My desired outcome is to create an automation that will do a write mem and then reload a series of switches and am hoping someone could give me the steps to get there. Thanks in advance.
georgehewittuk1
You could leverage EEM to schedule an event that does this and manage it on a template. E.g. a subset to reload at a certain time like the edge and the "core" to reload at another time. EEM event timer is what you need.
balaji.bandi
What is need to reload switches ?
you can use EEM Script to reload the switches - run external python script to reboot.
BB
