virtual DNAC on Nutanix
jpo1976
I am trying to install dnac as virtual appliance on Nutanix as a lab, I am using an ISO file version 2.3.5.6, I know there is an OVA, but I have not been able to make it work in Nutanix.
For the VM I put 32 cpus, 256 Gb Ram and 3 discs, 500Gb, 1T and 1T
The ISO file runs the maglev installer, but is never able to finish the  installation and I get this error:
 I was able to download all the packages manually
But I cannot deploy all the packages
There is always a message like this
DEPLOYMENT_ERROR - Exception in package: ndp-platform, kind: ServiceBundle, name: pipelineruntime-taskmgr-spa-apps - 'pipelineruntime-taskmgr-spa-apps 5.1.22' took more than the expected '350' seconds to start. Please review the service logs for errors.
I have tried reinstalling many times, also adding more resources to the VM, but I am not sure what is the problem here, does anyone can please provide some advice?
marce1000
 - Try to observe online memory and CPU usage when the VM is being deployed , look if some resources get exhausted for instance
  M.
marce1000
  - Added (2) : Not sure if native Nutanix is supported : https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/dna-center/dna-center-virtual-appliance.html#CiscoDNACenterVirtualApplianceforanexistingdeployment
     + https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2024/pdf/BRKOPS-2521.pdf
       Look at       Virtual Appliance (VA) Accomplishments
        and            Catalyst Center Virtual Appliances
  M.
AigarsK
Out of interest, did the install on Nutanix eventually worked? What is the status on this?
maflesch
Nutanix is currently not supported. Only ESXi on vCenter/VmWare is. Support for Azure and Nutanix is in development.
Outside of that, you cannot create a VM using the ISO. The requirements are different. You need at least 44 cores and 256 memory, for example. If you are trying to run a VM, then you should be using the OVA.
