what is IPAM in DNAc, what is use for?
Ahmed Tarek
Level 3
Level 3
hi all,
i need to ask what is the benefits for IPAM if i set configuration for it, i have DNS and DHCP server in my environment, so what is the purpose of IPAM?
i check out some guides for it, but still confused for the benefits for DNAc.
and what is IPAM required server component ?
any help ?
4 Accepted Solutions
balaji.bandi
IPAM - IP address Manangement (so DNAC can track the IP information)
if you have other IPAM in Place Like InfoBlox kinda you can integrade with them.
if not you can use build in DNAC IPAM
more information can be find here in the attached document.
BB
M02@rt37
Hello @Ahmed Tarek,
In environments where you have existing IPAM solutions like InfoBlox, integration with these systems is possible to ensure that DNAC can utilize the IP information and maintain a unified view of the network.
However, if you don't have a separate IPAM solution, you can use the built-in IPAM capabilities within DNAC. This allows you to manage IP addresses, track their usage, and coordinate with DNS and DHCP services directly within the DNA Center platform.
Best regards
 - FYI : https://www.youtube.com/watch?v=9r5ekxIxMYE
 M.
7 Replies 7
balaji.bandi
BB
M02@rt37
Hello @Ahmed Tarek,
Best regards
Ahmed Tarek
Level 3
Level 3
thanks a lot @balaji.bandi M02@rt37 for your usual help.
i will check and back to you
You're very welcome @Ahmed Tarek
Best regards
Ahmed Tarek
Level 3
Level 3
hi M02@rt37
i need any documentation for how use InfoBlox itself, to get all features i need to startup with DNAc
i mean all features available in infoblox
 M.
