Which license required to run BGP and create IPsec tunnel on 8200
MilanVerma17
Which license is required to run BGP and create an IPsec tunnel on Catalyst 8200-1N-4T
OrlandoGM
Hey @MilanVerma17,
You should be able to achieve that by using Essentials licensing (considering point-to-point IPSec tunnel).I would highly recommend to take a look at this Feature Matrix and refer to the "Cisco DNA for Routing perpetual features"section.
Something you need to be aware of as well is that you need to match the aggregated BW with the DNA licensing Tier.
Here is a quite comprehensive guide for ordering routing platforms + DNA Licensing:
https://www.cisco.com/c/en/us/products/collateral/software/one-wan-subscription/guide-c07-740642.html
Hope it helps!
Orlando González.
