Login banner not displaying when using CLI Analyzer
jrhallen
Frequent Visitor
Frequent Visitor
I have a login banner configured that works when I used programs like Putty, but when I use Cisco's CLI Analyzer my login banner doesn't show up. Is it because the username and password are entered before anything shows up on the screen? Is there a way to show the banner at all?
balaji.bandi
Login banner show as soon you enter username when you login:XXXX
what you see on cli analyzer (never used)
BB
The banner shows when I login using Putty, but nothing shows when I use cli analyzer.
