PCAP on CLI V3.3.2
SAM ANANDARAJAH
Hi ,
On earlier version of CLI, there was ability to capture PCAP from the screen on the bottom RHS , with this new version I find it difficult to do this ? .
if you try and get the PCAP , it directly points to CCO with login details.? on initial login , it used to be a function to click PCAP ? {I even clicked tools on display
I have tied on v3.31/3.3.2
it complains : cco login failed , also it refers to proxy server host must be added ? this may not be possible on certain times.
0 Replies 0
