Unauthorized to access Cisco IOS System Diagnostics. Authorization may have expired. Please re-login.
sgt2111usmc
It acts like it runs through the entire System Diagnostics and even takes a token away but then I get the:
Yes.  I'm logged in.
Suggestions???
joepak
How long does the diagnostics tool take? There could be an issue with how long an authorized user my be logged on.
Which diagnostic setting are you using?
