Cisco UCS Manager Plugin Release 0.9.3 for Nagios - Issues with plugin and autodiscovery
I am running Nagios Core 4.0.7 on a Fedora Core test server and have a UCSC-C220-M4 running firmware 2.0(3e) on the CIMC.
I've installed the Nagios UCS Plugin (0.9.3), ImcSdk-0.6.2 and UcsSdk-0.8.3.
Unfortunately whenever I either run the autodiscover (having given the correct IP, credentials and connection type in the config) or use the libexec/plugin, they both fail and report back errors.
Please see below - can anyone offer any suggestions on how to resolve this?
Thanks in advance.
Paul
************ Output from the IMCSDK test ************
[root@localhost ImcSdk-0.6.2]# python
Python 2.7.8 (default, Nov 10 2014, 08:19:18)
[GCC 4.9.2 20141101 (Red Hat 4.9.2-1)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import ImcSdk
>>> ImcSdk.__version__
'0.6.2'
>>> from ImcSdk import *
>>> h=ImcHandle()
>>> h.SetDumpXml()
>>> h.Login('1.1.1.1,'******','*******')
None ====> <?xml version="1.0" ?><aaaLogin inName="******" inPassword="******"/>
None <==== <aaaLogin cookie="" response="yes" outCookie="1430804378/bd87081e-154f-154f-8007-ee44d202b884" outRefreshPeriod="600" outPriv="read-only" outSessionId="14" outVersion="2.0(3e)"> </aaaLogin>
None ====> <?xml version="1.0" ?><configResolveDn cookie="1430804378/bd87081e-154f-154f-8007-ee44d202b884" dn="sys/rack-unit-1" inHierarchical="false"/>
None <==== <configResolveDn cookie="1430804378/bd87081e-154f-154f-8007-ee44d202b884" response="yes" dn="sys/rack-unit-1">
<outConfig>
<computeRackUnit dn="sys/rack-unit-1" adminPower="policy" availableMemory="65536" model="UCSC-C220-M4S" memorySpeed="1866" name="UCS C220 M4S" numOfAdaptors="1" numOfCores="16" numOfCoresEnabled="16" numOfCpus="2" numOfEthHostIfs="0" numOfFcHostIfs="0" numOfThreads="32" operPower="off" originalUuid="C7F87DE7-4293-4B78-8429-0B93CA807147" presence="equipped" serverId="1" serial="FCH1910V09E" totalMemory="65536" usrLbl="" uuid="C7F87DE7-4293-4B78-8429-0B93CA807147" vendor="Cisco Systems Inc" ></computeRackUnit></outConfig>
</configResolveDn>
None ====> <?xml version="1.0" ?><configResolveClass classId="networkElement" cookie="1430804378/bd87081e-154f-154f-8007-ee44d202b884" inHierarchical="false"/>
None <==== <error cookie="" response="yes" errorCode="ERR-xml-parse-error" invocationResult="594" errorDescr="XML PARSING ERROR: no class named networkElement" />
None ====> <?xml version="1.0" ?><configResolveDn cookie="1430804378/bd87081e-154f-154f-8007-ee44d202b884" dn="sys" inHierarchical="false"/>
None <==== <configResolveDn cookie="1430804378/bd87081e-154f-154f-8007-ee44d202b884" response="yes" dn="sys">
<outConfig>
<topSystem dn="sys" address="1.1.1.1" currentTime="Tue May  5 05:39:44 2015
" localTime="Tue May  5 05:39:44 2015 UTC" timeZone="UTC" mode="stand-alone" name="C220-FCH1910xxxx" ></topSystem></outConfig>
</configResolveDn>
True
******* Output from the nagios plugin *********
./cisco_ucs_nagios -H 1.1.1.1 -u ****** -p ****** --type dn -q sys/rack-unit-1
Error is of Type :   UcsException  Message >> [ErrorCode]: ERR-xml-parse-error[ErrorDescription]: XML PARSING ERROR: No such XML API method by name configResolveDns
Error while trying to run the UCS Nagios monitoring service.
Check for Nagios logs as it may help finding error details.
******* Output from autodiscovery *************
[root@localhost autodiscovery]# ./NagiosAutoDiscoveryUCS.py
UCS host information csv file   /usr/local/nagios/ucs/autodiscovery/UCSHostInfo.csv
/usr/local/nagios/ucs/autodiscovery/NagiosAutoDiscoveryUCS.cfg File exists
Removing the folder path : /usr/local/nagios/etc/cisco/ucsObjs
Copying the payload to /usr/local/nagios/etc/cisco/ucsObjs
Connecting to UCS - '1.1.1.1' with user '*****' and password 'xxxxxxxxxx'
Connect using NoSsl as 'False', port as '443' and  proxy as 'None'
Error while trying to discover :  1.1.1.1
Error is of Type :   Exception  Message >> cannot concatenate 'str' and 'NoneType' objects
Error while trying to auto discover UCS Infrastructure. Check if any of the UCS are reachable.
arusrini
Paul
I think you need the IMC plugin and not the UCS manager version.
Cisco IMC Plugin for Nagios (version 0.9.2)
Try this and let us know
Arun
arusrini
Paul
Arun
Thanks Arun - that explains it. I'm now getting a good response.
tripathiprateek
Hi Paul,
As I understand you are using UCS Nagios plugin to monitor a rack server.
This is the reason why you may be having issues with the plugin and
autodiscovery .
Try using the IMC Nagios plugin which can be found at
https://communities.cisco.com/docs/DOC-52673
Prateek Tripathi
Cisco UCS X-Series Energy Efficiency Offer
