Enable Persistant Volume on Cisco Containter Platform
Filip Po
I have CCP 2.2.2/Tenant Image 1.11.5 on Hyperflex 3.5.1(a).
Should be now supported the Persistant Volume Claim.
I used System Administration Guide to deploy HX FlexVolume cluster.
Cluster with storage provisioning vmware working well, but hyperflex storage provisioning end with error
DEPLOYMENT FAILED.
Screenshots with errors are attached.
My questions are:
- Are FlexVolume supported in CCP 2.2.2 on Hyperflex 3.5.1(a), yet?
- the k8-priv-iscsvm-network as Hyperflex Local Network has to be accessable through HX infrastructure? So it have to has a particullar configuration for VLAN on Fabric Interconnect? Yet I have this Network accessible only on vmware node with no bound to any physical Eth interface.
- or do i need to use tenant-image-1.10.11?
Thank you.
 filip@fipo-pvc-master59acc83886:~$ systemctl status cloud-final.service
  cloud-final.service - Execute cloud user/final scripts
   Loaded: loaded (/lib/systemd/system/cloud-final.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Fri 2019-01-25 10:07:23 UTC; 34min ago
  Process: 1270 ExecStart=/usr/bin/cloud-init modules --mode=final (code=exited, status=1/FAILURE)
 Main PID: 1270 (code=exited, status=1/FAILURE)
    Tasks: 1
   CGroup: /system.slice/cloud-final.service
           └─2334 /sbin/dhclient -1 -4 -v -pf /run/dhclient.ens192.pid -lf /var/lib/dhcp/dhclient.ens192.leases -I -df /var/lib/dhcp/dhclient6.ens192.leases ens192
Jan 25 10:07:23 fipo-pvc-master59acc83886 cloud-init[1270]: Failed waiting for coredns to be ready
Jan 25 10:07:23 fipo-pvc-master59acc83886 cloud-init[1270]: + exit 1
Jan 25 10:07:23 fipo-pvc-master59acc83886 cloud-init[1270]: Cloud-init v. 18.4-0ubuntu1~18.04.1 running 'modules:final' at Fri, 25 Jan 2019 09:52:42 +0000. Up 13.94 seconds.
Jan 25 10:07:23 fipo-pvc-master59acc83886 cloud-init[1270]: 2019-01-25 10:07:23,589 - util.py[WARNING]: Failed running /var/lib/cloud/instance/scripts/runcmd [1]
Jan 25 10:07:23 fipo-pvc-master59acc83886 cloud-init[1270]: 2019-01-25 10:07:23,595 - cc_scripts_user.py[WARNING]: Failed to run module scripts-user (scripts in /var/lib/cloud/instance/scripts)
Jan 25 10:07:23 fipo-pvc-master59acc83886 cloud-init[1270]: 2019-01-25 10:07:23,595 - util.py[WARNING]: Running module scripts-user (<module 'cloudinit.config.cc_scripts_user' from '/usr/lib/python3/dist-packages/cloudinit/config/cc_scripts_user.py'>) failed
Jan 25 10:07:23 fipo-pvc-master59acc83886 cloud-init[1270]: Cloud-init v. 18.4-0ubuntu1~18.04.1 finished at Fri, 25 Jan 2019 10:07:23 +0000. Datasource DataSourceOVF [seed=iso].  Up 817.53 seconds
Jan 25 10:07:23 fipo-pvc-master59acc83886 systemd[1]: cloud-final.service: Main process exited, code=exited, status=1/FAILURE
Jan 25 10:07:23 fipo-pvc-master59acc83886 systemd[1]: cloud-final.service: Failed with result 'exit-code'.
Jan 25 10:07:23 fipo-pvc-master59acc83886 systemd[1]: Failed to start Execute cloud user/final scripts.
Filip Po
If I use Storage Provider vmware instead hyperflex, then I had got a Persistant Volume Claim.
Cisco UCS X-Series Energy Efficiency Offer
