How to delete virtual drive in C-series using CIMC XML API
brlok
I am trying to research the fastest to clean up the C-series machines, the best way I thought is to directly delete all virtual drives using CIMC XML API.  I know how to the method of creating virtual drives but don't know to how to delete
For example:
dn="sys/rack-unit-1/board/storage-SAS-SLOT-HBA/vd-1"
sumbr
Level 4
Level 4
Hi Man Chung Lok,
If you want to delete all the virtual drives of the controller you need to specify adminAction=delete-all-vds-reset-pds.
For deleting all the virtual drives:
<configConfMo cookie="1460067895/e8ca7722-2fec-1fec-86ef-16752a2fa074" dn="sys/rack-unit-1/board/storage-SAS-SLOT-HBA" inHierarchical="false"><inConfig><storageController adminAction="delete-all-vds-reset-pds" dn="sys/rack-unit-1/board/storage-SAS-SLOT-HBA" status="modified" /></inConfig></configConfMo>
If you want to delete a particular virtual drive then you need to specify status=deleted for the storageVirtualDrive MO instance.
For deleting a particular virtual drive:
<configConfMo cookie="1460069519/40b0d7d2-2fed-1fed-86ff-16752a2fa074" dn="sys/rack-unit-1/board/storage-SAS-SLOT-HBA/vd-0" inHierarchical="false"><inConfig><storageVirtualDrive status="deleted" /></inConfig></configConfMo>
If you have the Cisco IMC PowerTool module installed on your system then you can try the below cmdlet for deleting the virtual drives.
PowerTool C:\> Get-ImcStorageController | Set-ImcStorageController -AdminAction delete-all-vds-reset-pds -Force -Xml
AdminAction        : no-op
Model              : Cisco 12G SAS Modular Raid Controller
PciSlot            : SLOT-HBA
Presence           : equipped
RaidSupport        : yes
SelfEncryptEnabled : no
Serial             : SV44532749
Type               : SAS
Vendor             : LSI Logic
Imc                : C240-FCH1851V0YK
Dn                 : sys/rack-unit-1/board/storage-SAS-SLOT-HBA
Rn                 : storage-SAS-SLOT-HBA
Status             : modified
XtraProperty       : {}
PowerTool C:\> Get-ImcStorageVirtualDrive -Id 0 | Remove-ImcManagedObject -Force
Let us know if you need more information on this.
Sumanth
6 Replies 6
sumbr
Level 4
Level 4
Hi Man Chung Lok,
AdminAction        : no-op
PciSlot            : SLOT-HBA
Presence           : equipped
RaidSupport        : yes
Serial             : SV44532749
Type               : SAS
Vendor             : LSI Logic
Status             : modified
XtraProperty       : {}
Sumanth
brlok
Awesome, thank you so much
for deleting all VD, it works~!!!
deleting single VD, not working but no error returning, just did nothing.
Hi Sumanth,
We have two flavors of controllers one SLOT-MEZZ and second SLOT-HBA .Which XML API i need to use to get this information. Based on the response, I need to construct the XML Request for Creating VD.
After VD is created , How can i achieve following
First, Initialize the VD
Second , Set the VD as Boot Drive
Suparn Bector
Hi Suparn,
You can run the Get-ImcStorageController cmdlet to get the list of storage controllers present on the server.
To initialise the VD
For fast initialization:
Get-ImcStorageVirtualDrive -Id 0 | Set-ImcStorageVirtualDrive -AdminAction start-fast-initialization
For  full initialization:
Get-ImcStorageVirtualDrive -Id 0 | Set-ImcStorageVirtualDrive -AdminAction start-full-initialization
To set the boot drive for a particular VD (For ex: ID 0)
Get-ImcStorageVirtualDrive -Id 0 | Set-ImcStorageVirtualDrive -AdminAction set-boot-drive
Let me know if need further help on this.
Sumanth BR
Thanks Sumanth,
I am looking for XML API's which can be called from a Java Client.
I was able to find these but only one XML API is left , which is to get the Controller Name.
I believe i need to change the "dn" value based on controller . Please correct me if i am wrong
create virtual drive
curl -k -d "<configConfMo cookie='COOKIE' inHierarchical='false' dn='sys/rack-unit-1/board/storage-SAS-SLOT-MEZZ/virtual-drive-create'><inConfig><storageVirtualDriveCreatorUsingUnusedPhysicalDrive dn='sys/rack-unit-1/board/storage-SAS-SLOT-MEZZ/virtual-drive-create' virtualDriveName='RAID10_12345678' raidLevel='10' size='3810880 MB' driveGroup='[1,2,3,4][5,6,7,8]' writePolicy='Write Through' adminState='trigger'/></inConfig></configConfMo>" https://<IP>/nuova
Initiating Virtual Drive
curl -k -d "<configConfMo dn='sys/rack-unit-1/board/storage-SAS-SLOT-MEZZ/vd-0' inHierarchical='true' cookie='COOKIE'> <inConfig><storageVirtualDrive dn='sys/rack-unit-1/board/storage-SAS-SLOT-MEZZ/vd-0' id='0' adminAction='start-fast-initialization'/></inConfig></configConfMo>" https://IP/nuova
Setting Virtual Drive as Boot Drive
curl -k -d "<configConfMo dn='sys/rack-unit-1/board/storage-SAS-SLOT-MEZZ/vd-0' inHierarchical='true' cookie='COOKIE'><inConfig><storageVirtualDrive dn='sys/rack-unit-1/board/storage-SAS-SLOT-MEZZ/vd-0' id='0' adminAction='set-boot-drive'/></inConfig></configConfMo>" https://IP/nuova
Suparn Bector
Hi Suparn,
Yes you need to form the appropriate DN based on controller and virtual disk IDs.
If you are looking for XML request and response for a particular action you can use -Xml parameter as part of any of UCS PowerTool cmdlets.
Sumanth
Cisco UCS X-Series Energy Efficiency Offer
