on 11-07-2013 02:41 PM
The following System Center Operations Manager Management Packs are available for download from Cisco:
Cisco UCS Management Pack Suite for Microsoft System Center 2012, Operations Manager (version 4.1.2)
Software Downloads:
(Above link requires cisco.com login)
Documentation links:
Video documentation links:
Details related to previous versions of Cisco UCS Manager and IMC Management Packs are as follows:
Cisco UCS Manager Management Pack v3.1.2 for Microsoft System Center 2012 - Operations Manager:
Cisco IMC Management Pack v1.2(1) for Microsoft System Center 2012 - Operations Manager:
External customers - For any issues, contact Cisco TAC (highly recommended for quick resolution) or add a discussion to the Cisco Developed Integrations sub-space on Cisco UCS Communities. Send your suggestions for new features to ucs-msft-plugins@cisco.com.
Internal (Cisco) customers and employees - Contact us at ucs-scom@cisco.com for support questions and ucs-msft-plugins@cisco.com for roadmap questions, new feature requests and feedback.
I had the same issue. Even adding my id into the admin group directly did not work.
I had to login with the server local admin account and then it worked.
v3.1.2
Hi All
Am trying to install UCS SCOM MP 3.1.2 on windows 2012 but getting some error while running the MSI file. As per some search, there is a bug in the cisco MP which relates to the link below.
https://tools.cisco.com/quickview/bug/CSCuv84558
If any one has come across this issue & has some solution to resolve this. Please advise.
Raghu
Hi Raghavendra,
The issue is because of user groups that might have circular membership. Please remove the circular membership of the groups or use a different 'USER' for installation which is member of 'Domain Admins'.
Tanmay
Hi Raghavendra,
Such issues might require some debugging to be done, it is better if you could raise a case with Cisco TAC
You can also raise a case with Cisco support team here:
Amit Kumar
Thanks Tanmay..... it resolved the issue when we tried with an different account which is not participating in any nested group.
Raghu
Thanks Amit for your help & response....
Hi All
From the availability point of view, wanted to check with does SCOM can generate availability report for all the UCS components in domain like FI, IOM, blade server, rack server & etc from out of the box solution using SCOM Management pack for UCS.
Raghu
Hi Amit,
I have an open TAC case. Can you pull it and try to contact me. I have tried most of the thing in this thread and still I'm not seeing any data being pulled in the SCOM monitoring >inventory section.
Juan Jimenez
Hi Juan,
I will require the TAC SR ID to look into the case, could you please provide that?
Amit Kumar
I was able to install and UCS Management Service and import the UCS management Packs into SCOM, (4.0.1) and nothing is being discovered into SCOM under Monitoring. The RunAs account being used is the same credentials used to log into the UCS Manager. Any assistance would be great. Thanks.
We are running Cisco UCS Management Pack version 4.1.1 on SCOM 2012 R2.
On one of our SCOM Management Server which monitors Cisco UCS Domain we see the Event ID - 19900 getting generated.
We require assistance to fix this issue.
The Details are as follows:
Log Name: operations manager
Source: Health Service Script
Date: 8/4/2017 1:43:10 PM
Event ID: 19900
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: NLDCASRV22.nl.kworld.kpmg.com
Description:
Cisco.Ucs.Performance.Collection.DataSource.ps1 : Data not received from Cisco UCS Monitoring Service or empty data found.
Date: 8/4/2017 1:43:19 PM
Event ID: 19900
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
Cisco.Ucs.LoadFaultCache.WriteAction.ps1 : The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the <serviceDebug> configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework SDK documentation and inspect the server trace logs.
We have the Cisco UCS Domain instances with UCSM Version 2.2(8d).
We have successfully imported the Cisco UCS Management Pack 4.2.1 and also upgraded the Cisco UCS Monitoring Service.
But while running the script to update UCS Instances we are getting the following message:
Even though the script generated the below error, we noticed the Custom Management Pack (Overrides - Cisco
UCS) in which the UCS instances are saved has also updated to version 4.1.2. So does this mean the UCS instances are updated?
Total number of configured UCS instances: 1
Updating UCS instance( 1/1 ): Overrides - Cisco UCS
ERROR: Could not fetch the template folder for instance Overrides - Cisco UCS
Exception Message : The term 'Update-UcsCentralScomAllInstances' is not recognized as the name of a cmdlet, function, s
cript file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is corr
ect and try again..Exception.Message
Exception Message : The term 'Update-ImcGroupScomAllInstances' is not recognized as the name of a cmdlet, function, scr
ipt file, or operable program. Check the spelling of the name, or if a path was included, verify that the path is correc
Press any key to continue ...
Hi Experts,
Anyone please assist/update on the above described issue.
Thank you!
Hi Sreejeet,
This error occurred because you do not have the UCS Central and IMC Management Pack in your SCOM.
And you ran the script without any switch.
In your case you should have run the script with -UCSManager switch to update only UCS Manager instances.
There are no issues updating UCS Manager instance.
-Amit Kumar
