asagade
Cisco UCS PowerTool Core suite is a set of PowerShell Core modules for Cisco UCS Manager, Cisco IMC and Cisco UCS Central, that helps in the configuration and management of Cisco UCS domains and solutions.
Cisco UCS PowerTool Core modules are developed using .NET standard to support PowerTool across the platform (Linux, Windows, macOS Operating Systems and Docker Containers).
The current offering of Cisco UCS PowerTool Core modules provides support for this new firmware:
  • Cisco UCS Center 2.0(1v)
UCS PowerTool core modules support matrix.
Windows: PowerShell 5.1 and above
Linux: PowerShell 6.x and above
UCS PowerTool modules v3.0.5.5 are available on the PowerShell gallery.
Cisco.UCS.Common : https://www.powershellgallery.com/packages/Cisco.UCS.Common/3.0.5.5
Cisco.IMC : https://www.powershellgallery.com/packages/Cisco.IMC/3.0.5.5
Cisco.UCSManager: https://www.powershellgallery.com/packages/Cisco.UCSManager/3.0.5.5
Cisco.UcsCentral: https://www.powershellgallery.com/packages/Cisco.UCSCentral/3.0.5.5
Above Module can be downloaded using the Install-Module cmdlet from the PowerShell gallery.
Example:
Install-Module -Name Cisco.IMC
Install-Module -Name Cisco.UCSManager
Install-Module -Name Cisco.UCSCentral
Release notes and Installation guide for the PowerTool core modules v3.0.5.5 is available here.
Release Notes:
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/All_Plugin_RN/PowerTool/3x/b-release-notes-for-cisco-ucs-powertool-suite-release-3x.html
Installation Configuration Guide:
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/msft_tools/powertools/ucs_powertool_book/3x/b_Pwrtool_Install_and_Config.html
Note: From release 3.0.0.10 onwards, UCS PowerTool core modules will be available only on the PowerShell gallery.
External customers - For any queries/feedback on PowerTool, contact Cisco TAC  or add a discussion to the Cisco Developed Integrations sub-space on Cisco UCS Communities.
