			on
		08-21-2015
		06:34 AM
 - edited on
		07-19-2021
		04:10 AM
 by
			amhetre
| Number | Description | Page Link |
| 1 | Power OFF unassociated UCS Blades | Power OFF unassociated UCS Blades |
| 2 | UCS Active Directory Authentication Integration Script | UCS Active Directory Authentication Integration Script |
| 3 | UcsInventory - creates an Excel spreadsheet with the UCS hardware inventory | UcsInventory - creates an Excel spreadsheet with the UCS hardware inventory |
| 4 | Quick Launch UCSM GUI PowerShell Script | Quick Launch UCSM GUI PowerShell Script |
| 5 | Multi-Domain UCS Configuration Backup Script | Multi-Domain UCS Configuration Backup Script |
| 6 | UCS Inventory Based User Labels for Servers PowerShell Script | UCS Inventory Based User Labels for Servers PowerShell Script |
| 7 | UCS WWPN Collector PowerShell Script | UCS WWPN Collector PowerShell Script |
| 8 | UCS Serial Number Collector PowerShell Script | UCS Serial Number Collector PowerShell Script |
| 9 | Generate SAN Zones for Cisco or Brocade with UCS | Generate SAN Zones for Cisco or Brocade with UCS |
| 10 | Checks the current bandwidth of all adapters in a domain | network-check.ps1 |
| 11 | Powershell: Auto-Update UCS Firmware Packages/Drivers to Multiple UCS Domains | Powershell: Auto-Update UCS Firmware Packages/Drivers to Multiple UCS Domains |
| 12 | UCS Base Configuration Builder PowerShell Script | UCS Base Configuration Builder PowerShell Script |
| 13 | UCS Power Control Blades PowerShell Script | UCS Power Control Blades PowerShell Script |
| 14 | UCS to Windows NIC Rename PowerShell Script | UCS to Windows NIC Rename PowerShell Script |
| 15 | Multi-UCS Domain KVM Launcher PowerShell Script | Multi-UCS Domain KVM Launcher PowerShell Script |
| 16 | Convert to UCS Cmdlet PowerShell Script | Convert to UCS Cmdlet PowerShell Script |
| 17 | UCS Available Slots PowerShell Script | UCS Available Slots PowerShell Script |
| 18 | UCS PowerShell Framework Script | UCS PowerShell Framework Script |
| 19 | UCS Firmware Upgrade with UCS PowerTool | UCS Firmware Upgrade with UCS PowerTool |
| 20 | Bare Metal Deployment of UCS Servers and Hyper-V with SCVMM and UCS PowerTool | Bare Metal Deployment of UCS Servers and Hyper-V with SCVMM and UCS PowerTool |
| 21 | Rolling UCS Server Firmware Upgrades and VMware Hypervisor upgrades using UCS PowerTool and VMware Auto-Deploy | Rolling UCS Server Firmware Upgrades and VMware Hypervisor upgrades using UCS PowerTool and VMware Auto-Deploy |
| 22 | Configure UCS and VMware vSphere to deploy bare metal UCS Servers using UCS PowerTool and VMware PowerCLI | Configure UCS and VMware vSphere to deploy bare metal UCS Servers using UCS PowerTool and VMware PowerCLI |
| 23 | Citrix XenDesktop Deployment using UCS PowerTool | Citrix XenDesktop Deployment using UCS PowerTool |
| 24 | Bare Metal Deployment of UCS Servers and Microsoft Windows 2012 with UCS PowerTool | Bare Metal Deployment of UCS Servers and Microsoft Windows 2012 with UCS PowerTool |
| 25 | Add and Deploy a new VMware Hypervisor on a Bare Metal UCS Server using UCS PowerTool and VMware Auto-Deploy | Add and Deploy a new VMware Hypervisor on a Bare Metal UCS Server using UCS PowerTool and VMware Auto-Deploy |
| 26 | Deploy UCS environment from scratch | Deploy UCS environment from scratch |
| 27 | Download Core and Techsupport file | Download Core and Techsupport file |
| 28 | Export UCS Managed Object | Export UCS Managed Object |
| 29 | Import UCS Managed Object | Import UCS Managed Object |
| 30 | Update UCS Manager Classic, FI and Server firmware using Host Firmware Pack | Update UCS Manager Classic, FI and Server firmware using Host Firmware Pack |
| 31 | Get CIMC IP report | Get CIMC IP report |
| 32 | Get DVS Config Report | Get DVS Config Report |
| 33 | Get global policies | Get global policies |
| 34 | Update UCS Manager Classic, FI and Server firmware | Update UCS Manager Classic, FI and Server firmware |
| 35 | Collect UCS inventory information | Collect UCS inventory information |
| 36 | UCS Hardening | UCS Hardening |
| 37 | Update the Host Firmware Policy | Update the Host Firmware Policy |
| 38 | Get NTP Server | Get NTP Server |
| 39 | Update Capability Catalogue | Update Capability Catalogue |
| 40 | Add Multiple VLANs for UCS domain(s) | Add Multiple VLANs for UCS domain(s) |
| 41 | Inventory of standalone UCS C-series and E-series servers | Inventory of standalone UCS C-series and E-series servers |
| 42 | UCS Bare Metal Server (Add / Remove) Demo Script | UCS Bare Metal Server (Add / Remove) Demo Script |
| 43 | Clone a NetApp C-Mode LUN to work with UCS | Clone a NetApp C-Mode LUN to work with UCS |
| 44 | Create Service Profile from Template | Create Service Profile from Template |
| 45 | UCS 3.x.x compatibility checker | Powershell: UCS 3.x.x Compatibility Checker (Get-ASUCSv31xCompatibility.ps1) |
| 46 | Bare Metal Provisioning Using VMedia with Powertool | Powershell : bare-metal-provisioning-using-vmedia |
| 47 | IMC LDAP Group Configuration | Powershell: imc-ldap-group-configuration |
| 48 | IMC Get overall server status | Powershell: imc-get-overall-server-status |
Thanks for the info
If I say thanks it will less to express my happiness for this article
Great! Awesome job!
Is there a IMC powertool script just to find out the current firmware version running on multiple C-series servers. If it is can someone share it.
Hi Sami,
I don't have a script, but here's a command to get you started
Get-ImcFirmwareRunning | select-object Deployment, Type, Version
John
Thanks John. This is good!
Hi ,
Is there any scripts to get the MAC collector from UCS domains?
What happened to the UCS 3.x.x compatibility checker script? It's gone.
Looking for a way to automate keyring regen. Is there a script of even a cmdlet to address?
Hi Heather,
You can use below cmdlet for keyring regen.
Add-UcsKeyRing -Name test1 -Regen true
Use "Get-help Add-UcsKeyRing -Detailed" for getting the details about cmdlets and parameters.
You can also use the ConvertTo cmdlet for generating Add command.
Get-UcsKeyRing | ConvertTo-UcsCmdlet
Rishi
I am trying to run the scripts that are present on this page, unfortunately I often have an error message with the CiscoUCSPS module that is not loaded.
I downloaded the latest version of powertool (2.4.1). I am in 4.0 of powershell.
I don't understand why it does not work. Can you help me please?
Thank you.
Bests regards.
Florian
thank you for your reply.
Best regards.
Florian
Is there a script to Create UCS Service Profile Template, not the server profile itself from existing template.
Hello Everyone ,
Is there any scripts which helps me to build a New UCS environment ?
Appreciate your help ............
