Help Need Advice For DNA Center IP Configuration
Hello Everyone,
I have issue regarding DNA Center IP Configuration
I would like to change my current cluster link because the existing condition is Cluster link on same interface web gui
is there any way I can change because I already tried but always the error "Change of IP Intra Cluster is not Supported"
Any suggestions are kindly appreciated
thank you
Best Regards,
Febry
Error: Change of IP address of the intra-cluster link is not
supported this is the error message
AKAIK a change of cluster link/ip requires a fresh rebuild. I know that was the case with 1.1.x and 1.2.x versions. Not sure about 1.3.x. My recommendation would be to contact TAC for further assistance. HTH!
I totally agree. Open a TAC Case, download the ISO (use FreeDownloadManager for this!) and reimage the server.
If you just want to change the IP of one node (and keep your cluster internal subnet), you can reintegrate it into the cluster. Otherwise I hope you can restore a backup to avoid setting all maps, devices, template, sites, etc. again - ask TAC. Good luck!
