SD-Access Fabric disable 802.1X for Wired connection
DuNguyen1212
Hi all,
I have SDA Fabric and all config pushed by DNA Center.
I see DNA Center push config relate to AAA (class-map, policy-map, template, assign template to interface)
I want disable 802.1x only wired connection.
Has anyone done this yet?
p/s: i had attach config file push by DNAC
Thank you very much for your interest!
DuNguyen1212
I want
Wired client will use MAB
Wireless client use 802.1x
 There are two ways to execute this. You can do it manually on the switch in ports assignment and chage the security.
Or you can create a template with necessary command, attach the template to a FIAB and apply to all or some devices.
Hi DuNguyen1212
So for MAB, ISE is still in place, so you need 802.1x configuration on the switches for wired authentication.
What I did so far in my deployments, you can change the order for the closed authentication template.
MAB first, then 802.1x.
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-2-3/user_guide/b_cisco_dna_center_ug_2_2_3/b_cisco_dna_center_ug_2_2_3_chapter_01110.html#task_ct1_syy_tdb
802.1x for the wireless client is configured through the SSID configuration
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-2-3/user_guide/b_cisco_dna_center_ug_2_2_3/b_cisco_dna_center_ug_2_2_3_chapter_0110.html#concept_3FEDBCEEC2F449CC950ABF06F78FD447
