Cisco intersdight inband KVM management unable to connect
roxyfoxtrotter
i keep getting this error when i try to connect inband management on a server in intersdight
when i click on the load KVM certificate. it goes to the management IP:2068 but nothing loads and goes to site cannot be reachedPicture1.png
We have seen similar behaviour when port 2068 is blocked between the client system and the inband management range. Can you verify if it is open using telnet or netcat?
