- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-08-2024 04:02 AM - edited 02-08-2024 04:03 AM
I have a potential case where 20 C220-M7 servers (each air-gapped) should be installed for video surveillance NVR. Each server is planned to be equipped with 8cores 16GB ram and few TB of storage where the OS will be installed directly (no virtualization).
The first M7 servers that came to us require Cisco Intersight as per documentation and also CIMC interface complains about it.
Can M7 servers at all be used in such Air-gapped environments ?
Or is it meant that I purchase 3-times the required resources (vCPU's and RAM), implement virtualization and run 20 on-prem Intersight VMs ?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-09-2024 12:20 PM
Intersight Essentials connectivity is required to use M7 servers, whether it be to Intersight SaaS, Intersight Connected Virutal Appliance (CVA) or Intersight Private Virtual Appliance (PVA).
If you say the servers are air-gapped, does that mean that they cannot get to the Internet, directly or via HTTPS proxy? If they can get to the Intenet via HTTPs proxy, you can claim them directly in Intersight SaaS.
If your servers can get to an Intersight CVA on your LAN, that will avoid the need for them to be able to connect to the Internet.
If your servers cannot get to a CVA on yourr LAN, you will need a PVA (which is air-gapped) which they can reach.
If these servers cannot connect to a central PVA, you may need compute for virtualisation to host the PVA (it can run on ESXi, Hyper-V or KVM).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-12-2024 10:33 AM
I hope that this guidance helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-09-2024 12:20 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2024 02:48 AM
Tnx, clear, then I need to add to the cost calculation for Cisco server option for this project 3x more HW resources (RAM and CPU) + virtualization + work to set up 20 on-prem PVA instances + the more expensive Intersight licenses that can work with PVA.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2024 11:37 PM - edited 02-10-2024 11:38 PM
I still don't understand how you go from "20 C220-M7 servers" for the 20 sites to "3x more HW resources (RAM and CPU)"? Are these 3 more servers per site? OR just adding more CPU & RAM to each of the sites?
You don't need the expensive Intersight license (Advantage). Your setup will work with the cheaper Intersight license (Essentials).
From my understanding, you have to license each Intersight-managed server. It does not matter if you deploy 1 or 20 Virtual Appliances, as long as there are licenses for the components they have claimed.
I will strongly recommend talking to your Cisco partner/reseller or Cisco themselves if you have the relationship to confirm the above and ensure that there is no other more cost-effective way to do what you want to.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-11-2024 07:14 AM
Simple mathematics. Have 20 air-gapped sites, each with 1 C220 M7 that requires Cisco Intersight access. As there is no connection to anything except local video cameras, I require on-prem Intersight Virtual Appliance on each of the C220 M7 servers. So in total 20 appliances.
As for the NVR OS+App I needed 8vCPUs and 16 GB RAM per each of the C220M7 server. The minimum HW requirements for an on-prem Intersight VM is 16vCPUs and 32 GB RAM + ESXi Hypervisor requrements - 2vCPUs and 12 GB RAM.
So, instead of 8vCPUs and 16GB RAM, now I need to have 26vCPUs and 60GB of RAM. This makes more than 3x resource increase. Please correct if I'm wrong.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-11-2024 10:31 AM
I have to correct myself. From the Cisco UCS C220 M7 Rack Server Data Sheet
E.g. Intersight with a PVA does not look like it is required. If I recall correctly, Cisco will only sell the M7 with an Intersight license (e.g. it is not optional), but you can run the server in regular “CIMC” mode.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-11-2024 01:33 PM
This was the reason why I raised the question here, because there is also Intersight docs, that say that it is required:
Cisco Intersight Infrastructure Service Data Sheet
Also the first M7 servers I have received (bought with SaaS license), display warning with text "Please note: Intersight Infrastructure Services license is required with this server". When asking some cisco guys - they told that without assigning the CIMC to some Intersight we are not assigning the license to the CIMC, so we are "breaking the EULA". But no one could me explain what is the correct way how to handle such cases.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-12-2024 10:33 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-17-2024 01:13 PM
I have serious issues with some of these statements. "Cisco Intersight licenses are required for all Cisco UCS M7 generation servers." WHY?! It is hardware. So you're telling me, that after I spend 10s of thousands of dollars on a server, I'm going to be required to pay a monthly/yearly license fee just to use the server? I'm already paying for support to keep the software components like the UCSM up-to-date, and now I have to pay an additional license? Tell me exactly why I should continue to use Cisco hardware at this point.
