FC Channel Adapters Not Showing on IMM C220M6
Crank
We have 12 new C220-M6. Eight were placed into UCSM controlled domains. Four were placed into an IMM domain.
The eight placed into UCSM controlled domains showed up as expected with the correct inventory, specifically the fiber channel adapters. The four placed into the IMM domain will not show the FC adapters in the inventory. The slots just show blank. I have upgraded the firmware, decommission/recommission, powered off/on, and tried changing several policies to get them to show up. I also went into the bios via KVM and attempted to look for the adapters and they do not show up there either.
The adapters are QLOGIC UCSC-P-Q6D32GF. It is a full blade. There are four total adapters and the two VIC cards show up as expected.
The UCSM domains are in Intersight and inventory shows up so I believe it is something to do with my policies or a limitation of IMM maybe?
Has anyone had this issue and know of a solution?
0 Replies 0
