HyperFlex Edge: Change of ESX Node IP causes trouble in Inttersight
alf
Hello;
I´ve recently installed a HyperFlex Edge Cluster with 3 x HXAF-E-220M6S using Intersight. The HX Version is 5.0(2a).
After successful deploment of the profile I saw that the ESX Management Adresses were not in the order I wanted them to be.
(In the Intersight Deployment Policy I gave a range with from / to, but I want to have Server-1 with the lowest IP and Server-3 with the highest IP). So I exchanged the ESX Management Adresses of Server-2 and Server-3 manually with the vSphere Client.
After this, in Intersight (Operate->HyperFlex Clusters-> (Cluster)->Operate->Hosts) I see only 2 of the 3 nodes and one node has double the resources as it should have (means Server-2 has the resources from Server-2 plus Server-3).
So what can I do to get this correct again ?
best regards,
Alfred
0 Replies 0
