01-25-2022 01:58 AM
Is it possible to disable RMA in Intersight SaaS consumption model?
If yes what are the possible ways?
02-03-2022 12:02 AM
Yes, Proactive RMA can be disabled in Cisco Intersight. Please see Opting Out of Proactive RMAs at https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/intersight/215172-proactive-rma-for-intersight-connected-d.html#anc12.
I hope that this helps.
Jacob Van Ewyk
02-03-2022 12:15 AM
Thanks Jacob
This option using Tags is applicable at account level only. Is that right statement.
Can we disable RMA in SaaS using API gateway ? If yes Please provide the instructions to do so.
Megha
