Intersight Virtual Appliance Installation
hafeezali
I am trying to install Intersight Virtual Appliance on vSphere ESXi node. After the selection of the ova image and storage option the step forwards to deployment option and finally to ready to complete. I am unable to find the customize template for assigning the IP, DNS, password and other parameters.
I tried with different version but unable to do that. Can anyone suggest where I am wrong?
Thanks and Regards,
Mir
Kirk J
So, just did a quick test, and I get the same thing, when going directly through an ESXi host's web UI.
Going through vcenter, and deploying the OVA prompts you for all the expecting IP and related info.
Will check, to see if that is expected for esxi direct deploy.
Can you confirm which exact ova version you are deploying?
Kirk...
Kirk J
So deployment requires Vcenter for deployment.  You cannot deploy directly through ESXi host individual vsphere GUI.
I have filed a request to update the documentation to clarify the requirements.
Thanks for calling this out.
Kirk...
