Showing results forĀ
Search instead forĀ
Did you mean:Ā
Management interface VRF Mgmt-vrf can not be removed. Cisco C3850-48P
Wizard4777
I am not able to delete this. Is this default?
Switch(config)#no vrf definition Mgmt-vrf
% Management interface VRF Mgmt-vrf can not be removed.
I also tried setting gi0/0 to default but it is not able to.
Switch(config)#do sh run int gi0/0
Building configuration...
Current configuration : 94 bytes
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
end
Switch(config)#
Switch(config)#default int gi0/0
% Management interface VRF can not be changed.
% Error(s) seen setting interface GigabitEthernet0/0 to it's default config
Switch(config)#
This interface is only for mgmt and can not assign to different vrf or to global
MHM
