Cisco CML IOSvl2 not booting
cisco8887
Level 2
Level 2
All
I have installed the CML on ESXi 6.7 and IOSvl2 does boot however gets stuck at the screen below.
I have plenty of CPU  and 128Gb of ram . does anyone have any suggestions?
I have expose hardware assisted virtualisation on the guest vm for CML enabled
export@cisco.com.
Cisco IOSv () processor (revision 1.0) with 722145K/62464K bytes of memory.
Processor board ID 98T5C8RVTTS
4 Gigabit Ethernet interfaces
DRAM configuration is 72 bits wide with parity disabled.
256K bytes of non-volatile configuration memory.
0K bytes of ATA System CompactFlash 0 (Read/Write)
0K bytes of ATA CompactFlash 1 (Read/Write)
11217K bytes of ATA CompactFlash 2 (Read/Write)
0K bytes of ATA CompactFlash 3 (Read/Write)
Martin L
anything else works? other images are ok? or just that one?  CLN has dedicated CML sub-forum group; you should go there;
https://learningnetwork.cisco.com/s/discussions
Regards, ML
**Please Rate All Helpful Responses **
all else seems to work yep, when I click on the link, there is no option to start a new topic there
