IOS-XE NetConf Filter Issue
Gerard2012
I am trying to get config from an IOS-XE device in CML2 and keep hitting the same issue when I try to filter the config elements I want to return.
I am trying to simply filter the hostname of the device in the first instance using a python script copied from the DevNet examples online.
Script:
from device_info import rdc1a
from ncclient import manager
# NETCONF filter to use
netconf_filter = """
<filter>
<native xmlns="http://cisco.com/ns/yang/Cisco-IOS-XE-native">
  <hostname></hostname>
</native>
</filter>
if __name__ == '__main__':
#    format = "%(asctime)s: %(message)s"
#    logging.basicConfig(format=format, level=logging.INFO, datefmt="%H:%M:%S")
    with manager.connect(host=rdc1a["address"],
                         port=rdc1a["port"],
                         username=rdc1a["username"],
                         password=rdc1a["password"],
                         hostkey_verify=False) as m:
        # Get Configuration and State Info for Interface
        netconf_reply = m.get_config('running', netconf_filter)
        print(netconf_reply)
This is exactly like examples I find online but in every instance if I try to use a filter I get the following error:
<?xml version="1.0" encoding="UTF-8"?>
<error-info
	xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"
	xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0">
	<bad-element>filter</bad-element>\n
</error-info>
It saying "filter" is a bad element? What am I missing here?
Thanks in advance.
Jackal
<filter xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
</native>
</filter>
 About this Error, you could see
bad-element means "An attribute value is not correct"
You can get more error type detail here:
https://www.bookstack.cn/read/rfc6241-zh/appendix-netconf-error-list.md
ChrisMott30064
Try the below in your filter:
  <hostname/>
</native>
