CIsco Modelling LAB - Missing Nodes
HallGarth
Hi All
I have re-installed cml2 after deactivating my license. I am now working with a new registered copy with full authorization. My concern now is when i create a lab, I'm only seeing 2 nodes - external connector and unmanaged switch, this has changed from what I have been using in the past. where i have a full array of device to build from. Please advise if this is the new normal, and how to view and use more nodes.
Thank you
Martin L
Did u attach image dvd to CML and set it as connected on power ?
see https://learningnetwork.cisco.com/s/question/0D56e0000BmdIpGCQU/only-seeing-2-nodes
if u still need help, go to official CML support at CLN
https://learningnetwork.cisco.com/s/topic/0TO3i00000094ZjGAI/cisco-modeling-labs-personal-community
Regards, ML
**Please Rate All Helpful Responses **
shin.sterneck
Hi HallGarth,
seems like you are missing the "reference platform and images". You need to make them available to CML by copying them over to local disk. Just mounting the refplat ISO is not enough anymore:
https://developer.cisco.com/docs/modeling-labs/#!copy-the-refplat-iso-to-disk
Shin
