CML 2.0 & Breakout tool won't display ports over telnet session using TERMIUS program
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-09-2020 02:47 PM - edited 06-09-2020 03:04 PM
Hi there, this is more FYI.
I've faced a strange problem on my CML2.0 installation. I've it installed on a ESXi server version 6.5.
I've spun up a lab with 6 IOSv nodes and use breakout tool to connect to devices via telnet since I run it on a remote server.
Although, if I run a "show run" command from the telnet session, the interfaces won't show up. But via the web console it will be fine.
- Chapters
- descriptions off, selected
- captions settings, opens captions settings dialog
- captions off, selected
This is a modal window.
Beginning of dialog window. Escape will cancel and close the window.
End of dialog window.
This is a modal window. This modal can be closed by pressing the Escape key or activating the close button.
I was connecting via OS X using a telnet client called "Termius" (available on windows as well).
Once I tried over a linux VM and the breakout tool it worked fine.
After installing telnet in OS X (Catalina, so I went via Homebrew) that was fine as well. Looks like this tool is not the best option for the Apple platform.
- Labels:
Cisco Modeling Labs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-11-2020 03:03 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-11-2020 02:49 PM - edited 06-11-2020 02:51 PM
Thanks! You're right.
Termius sends an "^@" each time you type "enter" which breaks the text continuation. Same problem found on the windows version I just tested.
But this app terminal options are pretty much scarse compared to PuTTY or MobaXterm on Windows so I couldn't change any parameter related to that.
Anyhow I'll use telnet client from the OS X terminal. Just wanted a more friendly way to connect to my labs without having to type in each device ip/port and have them from a single tabbed telnet client app (and yes a shell script may be an option).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-07-2020 06:09 PM
I have the same issue with royal TSX (had the same problem with terminus when trying to rule out royal TSX). Oddly enough, if I add an external connector and enable telnet on the VTY ports, the issue disappears. It seems to be specific to the breakout tool. Hopefully can find a resolution soon.
